List of "Approved" UPS Devices
    Not sure if this would work with all or only some UPS device, however, I am looking at upgrading and wanted to see if there was a comprehensive list of devices that the plug-in works with? Maybe it isn't even an issue but thought it was worth asking before spending a couple hundred on devices.
    I know it works fine with both of my two APC UPS's (which are different models). APC are the most common consumer ones you see at Costco, Best Buy, etc. I expect that any APC UPS with a "data port" on the back (which comes with a USB cable to plug into the computer intended to use APC's Powerchute software) will work with BLUPS.
    Word of caution: Don't install the APC Powerchute software that comes with the UPS. If you've already installed Powerchute, it must be uninstalled. Otherwise the Powerchute driver prevents BLUPS from getting data from the UPS. There is more info in other threads on this board.
