BLUPS faling
    BLUPS faling
    It's a CyberPower 825. Used to work. Now:
    Sep-27 12:44:55 PM Error Initializing plug-in(1): BLUPS Instance::No UPS battery exists on this system so this plugin will not run! Time to load: 174 milliseconds
    Sep-27 12:44:55 PM BLUPS Init Error No UPS battery could be found!
    Sep-27 12:44:55 PM BLUPS start Loaded configuration successfully
    Sep-27 12:44:55 PM BLUPS start BLUPS version is: 2.0.24.0
    Sep-27 12:44:55 PM BLUPS start Initializing BLUPS...
    Sep-27 12:44:55 PM Starting Plug-In Initializing plugin BLUPS ...
    Sep-27 12:44:55 PM Info Plugin BLUPS has connected. IP:127.0.0.1:50645
    Sep-27 12:44:54 PM Plug-In Finished initializing plug-in BLUPS
    The CyberPower App shows it's working and connected.
    BLUPS Version 2.0.24.0
    HomeSeer Version: HS3 Standard Edition 3.0.0.470
    Operating System: Microsoft Windows 7 Home Premium - Work Station
    Regards
    Michael
    Michael
    HS3, W10 Home, HSTouch, W800, Z-Stick+
    Some add'l info.
    Windows is managing the UPS. It shows up under Batteries in Dev Mgr, but in Power Options in CP there are no Battery options.
    And I did uninstall the CyberPower app after verifying it could see and manage the UPS.
    Regards
    Michael
    Michael
      Got it back. Had to uninstall the device and check the box to delete the drivers in Dev Mgr, unplug/plug the USB connection. Windows installed new drivers. Battery options showed up in Power Options. Stopped and restarted BLUPS. Another "crisis" averted.
      Regards
      Michael
      Michael
        Same problem
