Plug-in not updating device status for last power failure and restore
    The devices for last power failure and restore have not had their status updated in three years. The plug-in's log page shows the last power failure and restore was six days ago (for 3 seconds...just a brownout). Why doesn't the plug-in update the corresponding devices for last failure and restore? (All other devices update as they should.)
    I'm seeing the same issue with my setup. Performed a test this morning and see all the values being updated except the last power failure and last power restore date/times.
    Blade Do you know what might be causing this or what I can send you to help figure this out?
      Actually I do know why - it is because you changed the location and name of those devices
      Cheers,
      Bob
        Try out 2.0.25 in the beta section
        Cheers,
        Bob
          Thanks Bob, I installed 2.0.25 and gave it a try, but still no change.
            Blade Bob, I took your hint and renamed those two devices and put them back in the BLUPS location. They do work properly when setup like this, but I would really like to be able to reorganize with my own info if possible 😀. Thanks for having a look!
Name:	New Location.JPG
              Are you sure u are running 2.0.25
              It should be using the device address in 2.0.25 to update the devices
              Cheers,
              Bob
                Yes, I'm sure. I'll restart Homeseer to see if that makes a difference. Thanks.
                  Bob,
                  I renamed the devices to my own names and moved them to my own location, then rebooted HomeSeer. Also confirmed that the plugin version still shows 2.0.25 after rebooting. They still are not updating.
                    OK I need you to turn on debug logging in the plugin on the options page
                    Then trigger a power failure and then a restore
                    Then turn off debug logging
                    Attach the BLUPS-Detailed.log file zipped
                    It is in the HS3 root folder
                    Cheers,
                    Bob
                      Done. Thanks Bob, the BLUPS-Detailed.log file should be attached in a zip file.
                      Also, when going into the BLUPS settings pages, I noticed the status page does not display anything. Not sure if that has anything to do with this issue though.
Name:	Capture Status.JPG
                        Your debug settings are not set properly
                        Do the step in the first thread here and then delete the debug log and capture it again
                        https://forums.homeseer.com/forum/3r...-debug-logging
                        Cheers,
                        Bob
                          Done. Try this one.
                            Possibly just a hyphen missing or name formatting issue for the device name/address for the last power failure and last power restore devices?
                            Click image for larger version  Name:	Debug1.JPG Views:	0 Size:	70.6 KB ID:	1400010
                            Click image for larger version  Name:	Debug3.JPG Views:	0 Size:	30.8 KB ID:	1400011
                              Try out 2.0.26 in the beta section
                              Cheers,
                              Bob
