No longer detecting Power Outages
    #16
    Originally posted by Tomgru View Post
    I saw this... running win10 - so thought i'd check. the dashboard concerned me... with the date 5/21/1929 for the root status????
    but i ran a test, and it worked fine.
    any idea what the date is all about?
    Do you have any special drivers or software installed or you just using the default Win 10 drivers and functionality?
      #17
      not that i know of.....
        #18
        **SOLVED**
        This fixed my issue... it seems like a very strange fix.
        **** Update **** - There appears to be a Windows issue as after the system is rebooted it returns to the "Plugged In & Not Charging" state which causes the issues listed above in this thread.
        https://www.youtube.com/watch?v=gZRBbVuAwDk
        Had to re-install the battery driver and restart explorer.exe
          #19
          are you running a laptop by chance?
          I'm on win10... not seeing that issue.
            #20
            Using this:
            http://minix.com.hk/en/products/neo-z83-4
              #21
              I'm seeing this, too. Just had a minor glitch, which the "Power Failure" caught, but the "Power Restoration" did not. Running W10 with no issues, until about 2 weeks ago. It happened then and I thought it was a fluke, but just happened again.....
              No "Power Restoration" entry in the logs, at all.....
              Enabled Plug-Ins:
