Syntax error calling calender from event
  • Syntax error calling calender from event
    When i call calender from an event using "RetVal = hs.PluginFunction(Calendar, '', GetEvents())" I get a syntax error.
    HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
    BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
    BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
    Can you zip and post the Calendar.log file?
    -Larry
    A member of "The HA Pioneer Group", MyWebSite
    Plugins:
    VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
    Hardware:
    Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
      As Requested.
        I could not figure out why script command doesn't work as it looks exactly like previous versions that did work, but I did find typo's in the help file and corrected them. The event run script does work though if you want to use it.
        create a script like follows:
        Sub Main(parm As Object)
            Dim RetVal As Integer
            RetVal = hs.PluginFunction("Calendar", "", "CheckEvents", Nothing)
        End Sub
        this works for me, I am still trying to figure out why command does not work, I added a few other enhancements as well and submitted to updater. The new version is 3.0.0.31
        -Larry
        Plugins:
        Hardware:
          The new version is not in the updater yet. it is still 3.0.0.20, I'll keep watching and let you know how it goes.
            End Sub
            That works as a script, but calender has stopped announcing events, just say's there are no events today. Version3.0.0.31 is not showing in the updater just 2.0.0.20 which I have! Is there a way to download it directly?
              Update: 3.0.0.31 has appeared in the updater, dowloaded, will not run. Error is Not compatible with OS!!! I am running Windows XP Pro c with all updates except last months and Net4.
              Not to worry, I think, I am about to switch HS to Windows 2016 Server and hopfully that will solve the problem.
