cps tags and scenemaster cpu time
  • cps tags and scenemaster cpu time
    From this thread:
    https://forums.homeseer.com/forum/ul...tags-which-one
    I have 8 tags. one of them have like 10-12 devices. the other one have less.
    Some tags are used as condition , some as actions.
    I have maybe 8-10 events with tags in. here are examples
    nb: before I was using the same type of event with easytriger, and didnt see theses cpu time values
    just restarted the pc 30 minutes ago . do not know why some are green and some a white. Do not know much about htop
      What do you see in top vs htop?
        Hi Bill,
        here is a top vs htop view
          Found this on the net :O :
          By default, htop lists each thread of a process separately, while ps doesn't. To turn off the display of threads, press H, or use the "Setup / Display options" menu, "Hide userland threads".
          so..here's a new pic
            now seeing this from cps tag, I restarted my pc 3 hours ago. But this error was there like 3 there ago, so it logs non-stop since then
            Dec-28 01:54:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:53:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:51:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:50:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:49:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:48:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:47:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:46:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:45:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:44:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:43:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:42:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:41:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:40:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:39:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:38:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:37:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:36:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:35:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:34:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:33:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:32:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:31:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:30:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:29:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:28:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:27:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:26:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:25:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:24:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:23:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:22:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:20:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:18:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:17:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:16:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:15:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:14:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:13:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:12:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:11:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:10:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:09:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:08:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:07:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:06:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:05:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:04:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:03:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:02:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:01:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 01:00:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:59:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:58:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:57:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:55:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:54:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:52:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:51:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:50:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:49:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:48:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:47:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:46:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:45:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:44:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:42:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:41:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:40:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:39:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:38:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:37:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:36:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:35:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:34:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:33:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:32:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:31:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:30:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:29:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:28:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:27:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:26:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:25:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:24:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:23:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:22:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:21:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:20:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:19:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:18:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:17:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:16:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:15:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:14:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:13:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:12:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:11:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:10:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:09:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:08:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:07:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:06:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:05:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:04:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:03:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:02:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:01:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-28 00:00:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:59:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:58:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:57:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:56:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:55:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:54:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:53:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:52:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:51:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:50:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:49:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:48:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:47:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:46:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:45:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:44:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:43:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:42:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:41:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:40:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:38:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:37:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:36:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:35:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:34:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:33:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:32:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:31:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:30:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:28:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:27:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:26:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:25:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:24:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:23:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:22:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:21:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:20:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:19:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:18:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:17:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:16:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:15:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:14:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:13:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:12:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:11:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:10:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:09:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:08:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:07:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:06:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:05:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:03:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:02:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:01:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 23:00:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:58:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:57:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:56:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:55:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:54:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:53:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:52:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:51:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:50:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:49:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:48:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:47:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:46:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:45:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:44:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:43:07 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:43:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:42:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:41:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:40:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:39:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:38:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:37:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:36:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:35:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:34:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:33:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:32:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:31:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:30:07 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:30:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:29:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:28:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:27:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:26:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:25:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:24:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:23:12 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:23:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:22:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:21:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:20:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:19:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:18:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:17:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:16:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:15:00 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            Dec-27 22:13:12 Cps Tags Warning Invalid deserialized trigger data: 1116691499975
            and the cpu time are still high for tags and scene master plugins
              after deleting an even with cps tag as a trigger ( but no trigger selected), the warning went away. Cpu time still high
                I’ll fix the logging in the case of a partial event. Been looking at the cpu issue, can’t find an explanation and not matching what I’ve seen elsewhere (and my system of course)
                Can you confirm the versions numbers for both plugins?
                  Here is a screenshot
                    Thanks Matt. Both are very current (at least from the CPU work I've done in the past) Going to tackle Tags first. I have a theory that I'm checking on, will likely have a newer build for you to test sometime today-Monday. I'll post update here, but am actively working on it right now.
                      Hi Bill,
                      Again, thanks for you fast responses, and to your awesome commitment to your plugins and to linux hs3 users ( mono vbnc) .
                        Here is a htop screenshot I just took from my phone. I will take another one tomorow...My server didn’t run long enought
                          Hi. I am testing a fix now, I believe it will lower the Tags CPU usage. Down side, to fully get the benefit you will need to edit your events (not delete or recreate them, just edit them in the editor). I was not properly saving the condition vs trigger state, so every event change was evaluating all triggers/conditions instead of just the triggers. In all of your example events you are using Tags as conditions, so as devices change on your system no evaluation needs to occur for triggering purposes, but that was occurring. There is no easy way to query HS and get enough info about an event for me to automatically fix this, but where I could take hints from the system I did (meaning it should be faster regardless, but the full improvement involves touching those events so that state gets recorded).
                          Just rebooted so I can watch CPU usage in context to the rest of the system over the next few hours.
                            A better picture of the situation
                              That is good for me.
