As the title states...new dimmer, unable to control within Scenemaster as the error below is showing on the interface. Any ideas?
Added new WD200, showing in Scenemaster as vspair:error
Tomadoggy, This means that the device you selected to control doesn't have any control/status pairs defined. I usually get this when I accidentally select the root/parent device instead of the feature/child device for a scene. Since this is an HS3 legacy plugin, you won't get the "Select Device" then "Select Device Feature" dialog like you do with an HS4 native plugins.
Hope this helps,
Ken"if I have seen further [than others], it is by standing on the shoulders of giants." --Sir Isaac Newton (1675)
