Linux supported?
  • mikemack
    The correct fix for this issue is in the latest version in the updater 1.2.2.0.
  • mikemack
    I'll take a look at how to adjust this.
    I can't check now, but I think you can do a temp fix by editing the HSPI_scenemaster.exe.config file in the HS3 dir. Search for "Config" and "Data" and change the surrounding path elements.
    Thanks for the feedback!
    Mike
  • zigmund
    works fine, but log and config filenames are invalid
    Hi Mike,
    the plugin is working but I noticed the config files are not saved properly in Config folder because of windows filepath seperator '\' in linux.
    also the log file not saved in Data folder but in homeseer root folder.
    homeseer@hs3:~$ ls -l *hspi_scenemaster*
    -rw-r--r--  1 homeseer homeseer     213 Oct 20 21:49 Config\hspi_scenemaster_config.xml
    -rw-r--r--  1 homeseer homeseer    3641 Oct 19 23:06 Data\hspi_scenemaster\log\scenemaster.txt
    homeseer@hs3:~$
    and even more invalid folders:
    homeseer@hs3:~$ ls -lR usr
    usr:
    total 4
    drwxr-xr-x 3 homeseer HS4096 Oct 18 20:32 local
    usr/local:
    total 4
    drwxr-xr-x 5 homeseer HS4096 Oct 18 20:32 HomeSeer
    usr/local/HomeSeer:
    total 12
    drwxr-xr-x 3 homeseer HS4096 Oct 18 20:32 bin
    drwxr-xr-x 3 homeseer HS4096 Oct 18 20:32 docs
    drwxr-xr-x 3 homeseer HS4096 Oct 18 20:32 html
    usr/local/HomeSeer/bin:
    total 4
    drwxr-xr-x 2 homeseer HS4096 Oct 18 20:32 hspi_scenemaster
    usr/local/HomeSeer/bin/hspi_scenemaster:
    total 0
    usr/local/HomeSeer/docs:
    total 4
    usr/local/HomeSeer/docs/hspi_scenemaster:
    total 0
    usr/local/HomeSeer/html:
    total 4
    usr/local/HomeSeer/html/hspi_scenemaster:
    total 0
    homeseer@hs3:~$
  • mikemack
    Just tested; works fine on Linux.
    Mike
  • mikemack
    I have not tested with Linux yet -- I will add this to my TODO list and report back ASAP.
    In theory it *should* be compatible with Linux, but that does go against the basic principle of SW development -- If you didn't test it, it doesn't work. :-)
    Mike
  • zigmund
    started a topic Linux supported?
    Linux supported?
    Hi MikeMack,
    Is Linux supported?
