Virtual device not created
  • Virtual device not created
    Hi,
    i am not able to create a virtual device . I cheked multiple times to find the virtual device in the webcontrol section of homeseeer and i do not see it.
    edit:
    ok i understand, you have to create the virtual device mannually first
    is there a way to control all the device created in the tag , with the virtual device?
      Hi. (Sorry for the delay, I was running the Baja 1000 and just got back to civilization).
      Yes, you can control all items in a tag one of two ways. You can use the virtual device or you can use the actions added by Tags. In either case, Tags will try to do the 'right thing' If you send a 'Blue Light On' command to 20 devices, 1/2 of which support 'Blue Light On' then only those devices will get send the command (since it is meaningless to the other devices). If you set the device to a value (say '50') then all devices will get set to that.
      You can use the actions for almost all control issues, the virtual device gives you the ability to take action on the highest, lowest, or average value of all the devices in a Tag (I use it to take an average of my temp sensors to make heating/cooling decisions in an area).
        When creating the virtual device manually how does it link up? Do I use a specific name? Type? Address?
          Hi, simply check the 'virtual device' option in the configuration panel and it will create the virtual device (or remove it if you turn off the check mark). I didn't build a way to support creating them manually, I imagine I could. Do you have a use case?
          Best
          Bill
            Post #1 said to create manually but I didn't know how. Now I understand it's automatic.
              I just tried and can not find the created virtual device in my list of devices. What is the default room and category of the created device?
                I think I found the problem
                Jan-03 7:50:02 PM Error Posting back to plugin web page CpsTagsConfig: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
                Jan-03 7:50:02 PM Error Calling HSEvent in plugin Cps Tags, Instance :Object reference not set to an instance of an object.
                  That error would suggest the plugin is not running. Can you disable/enable it on the plugin page and see if it repeats?
                    I think the plugin crashed and then restarted. I have tried several times after restarting the plugin.
                    Question: Is it necessary to hit save all changes after clicking the "Create virtual" because it seems to do nothing if you don't hit save but crassed if you do. Are there any debug settings I can turn on?
                      Correct, all the editor changes are not applied until you save. There should be an exception file in the homseer directory (homeseer created). If not I will have to add more debug logging to see what is occurring, this is the first instance Ive seen of this.
                        No exception file I could find. Also I have determined that anytime I hit save the plugin crashes and disconnects and requires cycling regardless if I was attempting to create the virtual.
                          I'm experiencing the same behavior. Save. Crash. Disconnect. Restart. Lather. Rinse. Repeat.
                          My home is smarter than your honor roll student.
                            Could you both kindly post your config (windows or linux, version #)?
                              Current Date/Time: 1/6/2018 3:53:42 PM
                              HomeSeer Version: HS3 Pro Edition 3.0.0.318
                              System Uptime: 0 Days 0 Hours 56 Minutes 13 Seconds
                              IP Address: 10.10.10.249
                              Number of Devices: 3275
                              Number of Events: 433
                              Available Threads: 3200
                              Enabled Plug-Ins
                              3.0.0.1: Alexa
                              3.2.0.5: APCUPSD
                              2.0.49.0: BLBackup
                              2.0.8.0: BLCpuAdvisor
                              2.0.3.0: BLDatabase
                              2.0.8.0: BLEditor
                              2.0.9.0: BLEmail
                              2.0.1.0: BLFloorplan
                              2.0.5.0: BLGarbage
                              2.0.48.0: BLGData
                              2.0.8.0: BLIcon
                              2.0.5.0: BLLatestImage
                              2.0.75.0: BLLock
                              2.0.9.0: BLLogMonitor
                              2.0.7.0: BLMapper
                              2.0.2.0: BLMovies
                              2.0.22.0: BLOccupied
                              2.0.54.0: BLOnkyo
                              2.0.10.0: BLPlex
                              2.0.6.0: BLPlugins
                              2.0.132.0: BLRadar
                              3.0.15.0: BLReminders
                              2.0.12.0: BLRoombaWifi
                              2.0.3.0: BLRSS
                              2.0.34.0: BLSecurity
                              1.0.3.0: BLShutdown
                              2.0.71.0: BLSpeech
                              3.1.1.24385: Blue-Iris
                              2.0.5.0: BLVolume
                              3.0.0.10: Chromecast
                              1.0.0.0: Cps Flash
                              1.0.0.0: Cps Tags
                              0.0.0.3: Device Comparison 3P
                              1.2.2.0: Device History
                              1.0.0.0: drhsEventEnabler
                              0.0.0.31: drhsIpPlugIn
                              3.0.0.3: DTSDeviceImages
                              3.0.0.42: EasyTrigger
                              1.0.16302.20: EventGhost
                              3.0.0.4: FaceRecognition
                              0.2.0.10: FitbitSeer
                              3.6.5.0: Harmony Hub
                              3.0.0.98: HSTouch Server
                              3.0.0.25: ImperiHome
                              3.0.0.54: ISYInsteon
                              3.0.1.10: Kodi
                              3.0.0.4: Log2Text
                              2.17.0.19: MCSSPRINKLERSP
                              3.0.0.28: MediaController
                              1.1.17344.311: MyQ
                              3.0.0.14: NetCAM
                              3.0.1.109: PHLocation
                              4.0.3.0: PLEXMONITOR
                              0.0.0.35: Pushover 3P
                              1.0.0.6: Restart
                              30.0.0.36: RFXCOM
                              1.2.2.0: SceneMaster
                              3.0.5.6: SDJ-Health
                              3.3.5.17921: SMS-Gateway
                              3.1.4.15: SqueezeBox
                              3.0.4.4: Tasker Plugin
                              3.0.6551.16959: UltraGCIR3
                              3.0.6561.37908: UltraLog3
                              3.0.6554.33094: UltraMon3
                              3.0.6413.20219: UltraNetCam3
                              3.0.5902.19061: UltraSMTP3
                              3.0.6496.15709: UltraTivo3
                              3.0.6542.35207: UltraWeatherWU3
                              3.0.0.21: VWS
                              3.0.0.79: weatherXML
                              3.0.1.130: Z-Wave
