I have three Tuya LED bulbs I'm using to test both Tags and SceneMaster. My goal is to control the on/off and color of all three bulbs that will eventually be installed in a ceiling fan.
I started out with:
1. Blue Room Smart Bulb_1
2. Katie's Room Smart Bulb_2
3. Katie's Room Smart Bulb_3
I had #1 in a #Tag called #BlueRoomBulbColor. I had #2 and #3 in another #Tag called "#Test".
I moved #2 and #3 from Location2 "Katie's Room" to "Test Bench". Location1 for all devices is "Cps Tuya" representing the technology used.
Now for the problem:
I removed all of the rules from "Test" which basically deleted the #Test tag. When I try to create a new #Tag called "#TestBulbColor" and select "Cps Tuya" for Location1 (i.e. Technology) and here's the results:
Notice that Devices in Tag still show the old Location2 "Katie's Room". What's even weirder it that if I enter "Test Bench" for the next rule it still finds devices but shows the old Location2 "Katie's Room":
If, on the other hand, I change "Test Bench" to "Katie's Room" no devices appear in the tag:
Let me know if you need me to collect additional information.
Ken
I started out with:
Ken
