When operating a Virtual Device the tag "member devices" do not change state.
  • When operating a Virtual Device the tag "member devices" do not change state.
    I must have something wrong... everything is there but nothing happens
    CPS Tags version 1.0.9.0
    HS3 Pro Edition 3.0.0.531 (Windows)
    Here is a link to downloaded for the latest version (copy this file into your HS directory then use the updater to load the latest).
    http://download.casapiedrasoftware.i...r_override.txt
    This version will be in the updater later this month.
    Best
    Bill
      hi Bill, bsobel
      is 1_8_0_0 the last cpstag version?
      I see version 1.15.13.0 here:
      https://forums.homeseer.com/forum/ul...-do-not-appear
        I had a special trigger case :
        what i wanted to do is ... ''if between 2-5 windows are open ( 100) ''
        but when i use iff at least 2 windows are open(100) it triggers at 2 and then at 4 windows.
        i would like it to triger only one time when it enters the range 2 to 5....what the nukber of windows that are open.
        i would also like to do the same with 0 to 1 windows open.
        adding a range trigger would be convenien.
        thank you
