Apologies to everyone for the challenges with this new version - as I've mentioned, it was a major architecture change and code refactoring exercise, so I knew there would be bumps; I just didn't expect quite so many
Known issues right now:
Here's the status as I understand it:
My first priority right now is to figure out the DLL issues on Linux. Next up will be Favorites & Device tabs.
If you're having problems, I really, really need you to post as many of the details as you can per the Having problems? Follow these steps first. post. I get you might not be able to provide log files easily, but if you have an INI file from the plugin, you can change the LogLevelFile value to 6 manually and then start the plugin. That will get me the most detailed information and help me resolve your issue as quickly as possible. (Note: I don't need that for the Linux Interop DLL issue at this point).
- Charts on the DH device tab don't come up
- Plugin won't connect to the database on Linux (SQLite Interop error)
- Favorites not loading
- HS3 on Windows
- Working
- Not Working
- HS4 on Windows
- Working
- Not Working
- No reports
- HS3 on Linux
- HS4 on Linux
- Working
- No reports
- Not Working
- No reports
- Working
