Way to filter bogus values?
    I am monitoring some electrical usage for my washer and dryer...on occasion, but regularly, bogus values appear...e.g. watts on the washer this past week showed up once as 5368709.1 and this was at a time when the washer was not being used and watts were otherwise logging as zero. Could there be a way to set a max value for the y-axis which would in effect filter out these high values, as otherwise the graph gets so skewed to allow them to plot that regular actual measurements end up being mere dots down near the x-axis, and observations for average value also also skewed. Thanks.
    You should be able to do this by setting min/max values on those devices on the Monitored Devices tab. Check that out and let me know if it takes care of that for you!
      I've done that but do I conclude that the max setting i put in refers to only NEW values? As when I subsequently go to look at the chart I am still seeing the five million plus value despite having set a max of 1000. Thoughts?
ID:	1447517Click image for larger version
