Fails to start: Object reference not set to an instance of an object
    When checking a trent in my HS4 today, I noticed that the Device History plugin had stopped, it was not in the list of installed plugins.
    When trying to reinstall it, I get the above error in the HS4 log.
    I have tried to set the log-level to 6 in the ini-file, but no updated file is saved in the Logs folder.
    I previously had this problem, until a HS4 update solved the problem. One of the things that was in the release-note for the HS4 update, was something about localization format or something. I use "en_GB.utf8" as locale settings file.
    But - I just got if working again, using "en_DK.utf8" - might there be a bug, not supporting all types of locale? That the GB is not "supported"?
    Brg
    Truls
