ok i know i am missing something obvious here, but i need to check. when evaluating values in a device group, you state that the group can be defined by Name, Location1, Location2 or Type.
I get the location 1 & 2 tags, but the Name and Type fields i dont 100% get, does the name field accept wildcards (*) and lastly the Type Field, when looking at the device which type field does this correspond? is it the Node Type, or Device Type field this corresponds, and does that accept wildcards (*)
the best solution for this would be that you can specify any device with Location 2 as say living room and the type is *Motion*, but it doesn't look like you can compound the evaluation?
Regards
Stuart Buchanan
Regards
Stuart Buchanan
