I have two routines that compare the temperature from a Fibraro sensor (using easy trigger) and then updates the high or low value accordingly and it worked fine. I had an issue and somehow managed to lose the device node. So now having re-included the device was trying to fix the various events.
When I now try to select the temperature child device in the easy trigger routine it is not available to enable the comparison.
I upgraded to windows 10 about two weeks ok. Other Fibraro devices added before the upgrade compare fine.
Steve
Steve
