Target Plus 2 Comparison
  • Target Plus 2 Comparison
    Working with a Thermostat, I would like to have the setpoint say 72, and if the temp goes +2 from that, it triggers. I fenangled this, but it really doesn't look right. Thoughts? Edit; It kinda looks right.. Can I get a Homework check? lol
    I think you want ">=" instead of ">".
    Either that or leave it ">" and change to "+1".
      You were correct.
      How do you trigger on just the temp being >=74. No comparison between two numbers. Not a trigger, but a condition.
        You were correct.
        HS has some native trigger/conditions to compare values "this device had its value set and is greater/less than"
        When used as a condition (i.e AND IF), the "had its value set" part is ignored only the value is tested.
