Rename Easytrigger Schedules & Device Groups
    HI,
    Am I being totally blind or is there no way of renaming Schedules or Device Groups within EasyTrigger Config. Just deleting them and adding them in again ?
    I can only see a Delete button and the dialogue just allows Editing of the content, not the actual name.
    Cheers
    David
    Unlike HomeSeer devices and events, Easy Trigger schedules and groups do not have Reference IDs, they are referred only by their names. Since both are referenced by their names in Events, it is best to avoid renaming them. That said, you can edit EasyTrigger.ini to change the names. You will have to edit every event that references the schedule or group that you renamed. I edit the ini file to sort the names while HomeSeer is down. When it is restarted the the changes are reflected.
    You can also copy the contents of an existing schedule and paste them into a new renamed schedule.
    HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
