EasyTrigger Schedule Delays
  • EasyTrigger Schedule Delays
    Hello Spud,
    I have a couple of events setup that use the EasyTrigger schedules, for the events that use "Enters XYZ Time range" I notice that there is anywhere from 15-25 second delay between when the time range starts to when the device triggers. Is there any way to eliminate this delay within the plugin?
    Thanks Spud!
    Plugin's:
    The plugin runs a timer that check every 30 seconds if some schedule triggers need to be fired, so yes delay can be anything from 0 to 30 seconds. Since the ET schedules have themselves only 1 minute precision I thought it wasn't a huge problem.
    That being said there is certainly better ways to implement this that will result in almost no delay, so I will add that to my TODO list.
      Please test version 3.0.0.54 available in the Beta section of the updater, there should be almost no delay now
        Just updated! Thank you sir!!
        Plugin's:
