Change ETDeviceName Variable
    Basically I want to change the the text in the variable. I am creating push notifcation and using $$GLOBALVAR:ETDeviceName: is now $$GLOBALVAR:ETDeviceStatus:!
    The text comes out as Room then device name. I dont need the room so I would like to strip that off.
    The notication looks like
    Garage Mike's Door
    I would like to strip garage and update a variable with Mikes Door and use that in the push notifcation. Can i great and event and use regex?
    Mike
    themlruts - Use the updated version of the plugin -- found in the Manage Plugin beta section. It now uses separate global variables for the device location information and the name variable is now only the name.
      I just installed the beta. Its working great. I just want to make sure this event looks correct. It works but I want to make sure its best practice.
        Looks fine to me!
