Run event if expression is true
    Hi all,
    In my house, I have a daily time of day based light level virtual device that changes throughout the day. There are then other events for specific lights that set the actual light level to the virtual device level when it changes. For some lights, I have a second virtual device I call a trim adjuster. If my global time of day device level is too bright for that specific light, I can trim the level the light is set to be more appropriate without having to change a bunch of other events. I do this with an event that sets the device to an expression: "$$DVR:434:+$$DVR:704:" (for example). The trim device (704) has a status range of -50 to 50.
    So, with the above in mind, I am trying to figure out a way to only set the device to the sum of the above expression if the value is greater than zero (or some other low number).
    IE:
    IF SpecificDevice is not OFF
    AND IF TimeofDay_Device changes
    AND IF TimeofDay_Device+TrimeDevice is > 0
    THEN
    Set Device to Expression: $$DVR:434:+$$DVR:704:
    Hope this makes sense, sorry if I am missing something obvious.
    Thank you!
    I've not used this type of functionality with easytrigger yet but this post appears to explain exactly what you're looking for.
    -Wade
      Originally posted by fx12002 View Post
      Hi all,
      IE:
      THEN
      Thank you!
      First of all, I think the trigger should be the TimeofDay device changing and the condition would be the device not being Off. You could probably use the Min or Max functions in the expression to set upper or lower limits. See this thread
      https://forums.homeseer.com/forum/ul...in-easytrigger
      HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
        Thank you for the replies. I did see those links but don't know the correct syntax/ structure to string it all together. At minimum, I realized by changing the trigger order I can at least only run the event if the value would be greater than 0 (or whatever lower limit value).
        Then have a second event that would run instead. But, like you said Randy, I think I may be able to use the min/ max functions all in one expression that would be more elegant. But, I have no clue how to structure it!
        Thank you for your help,
        K.
          K.
          I'll take a stab at it and post back. I think it might be possible to use Min and Max to keep the value from being less than a threshold and to prevent exceeding the maximum of 99 for a dimmer.
          Just to be clear you have a light (dimmer) that you want to adjust its value up or down by yout TimeofDay (+- value) device offset by a trim device (trim). This would be dimmer+TimeofDay+trim? Then you would want this to be no less than a minimum and no greater than 99. Does all this sound correct?
            I need to know the value ranges for your dimmer, TimeofDay and Trim devices and exactly how you apply them. I just tested this and it works perfectly based on my assumptions.
            Dimmer = 718
            TimeofDay= 721
            Trim = 610
            Min(Max (($$DVR:718:+$$DVR:721:+$$DVR:610: ,10), 99)
            This will Take the dimmer, add the TimeofDay and trim values and constrain it to a minimum of 10% and a maximum of 99%.
            I do see a problem in my assumptions, that is why I need to know exactly what you are doing.
              This works too:
              if($$DVR:434: + $$DVR:704: > 0, "$$DVR:434: + $$DVR:704:" , "0")
              The last "0" in the string is value if false, so you can change it to whatever you want (another expression or another device value).
              --Barry
                Originally posted by logman View Post
                This works too:
                --Barry
                As is usually the case there is more than one way, but that doesn't catch the value exceeding 99, since his trim device has a value range of -50, 50.
                We both still need to understand his logic with the three devices involved.
                  Thank you both for your replies, this is very helpful. Randy, your understanding of what I am doing is exactly correct. I haven't been able to test yet but this looks like it would work perfectly. Regarding the possibility of specifying a dimmer value above 100%, this could happen and if it is an issue I guess depends on if you set a device to a value outside of its range, does it not execute the command at all or will it go to the highest possible value within its range. For example, coming from Smartthings, if I set a device to 150% level, it would set it to 100% and in the log would show the error.
                  Barry, thank you for your reply as well, I will test both. Also, this has been extremely helpful as a reference for me to see the syntax for this type of logic.
                  Thanks again, will test tonight.
                    I think the action will fail if you try to set the Device's value outside the configured range in the VS settings. If you try to set a dimmer to 120% it will just fail. If you use the expression I posted it will constrain the values to what the dimmer can handle at the top end and set a floor at the bottom.
                    It is also important for me to understand your logic, because I can see a cumulative error in what I posted, because of affecting the device value each time and having the device value as part of the calculation.
                    Assuming you are just setting the dimmer to the TimeofDay device plus the trim it would be
                    Min(Max (($$DVR:721:+$$DVR:610: ,10), 99)
                    Here everything works
                    Here it would calculate to -22% so it stops at 10%
                    Here it would have calculated to 135% so it stops at 99%
                      Hi,
                      So testing everything, I think I may be doing something wrong ... when I set the trim adjuster, the light dimmer level jumps to 99%. I included an image of what I have and here is what each device is:
                      446 = Actual dimmer
                      434 = The time of day level
                      704 = Trim adjuster.
                      Thank you for your help!
                        Hi,
                        446 = Actual dimmer
                        That is what I was trying to explain in my post #10 above. Take the actual dimmer out of the formula. I reread your initial post and I am thinking that will work.
                          Hi Randy,
                          Thank you, I now understand what you were asking. Removing the actual dimmer caused the event to work exactly as needed. Thank you all for your help with this, I appreciate it!
