Just installed the plugin to monitor the change of a string on a virtual device but the event created never triggers.
I have created a virtual device :Id:1170 named DEVICE TEST where the string is set via json to "empty"
I created the following event:
If DEVICE TEST has a string that just changed
then send pushover message
I then send the following Json command to modify the string of devie 1170:
http://192.168.1.6/JSON?request=setd...ty=NewDevStrin g&value="aaaa"
I looked in the device advanced tab and the string parameter was changed to "aaaa" BUT I never received the pushover message and looking in the event I see that the event was never trigger
Can someone shed some light on what might be wrong ?
thanks
update: just activated the debug mode, I can see many string changes on the log but even if i run the JSON command descibed before ,I never see the device id used in the JSON appear in the log
found this thread dating from 2017... can't belive Homeseer did not fixed the issue yet !!! https://forums.homeseer.com/forum/ho...86#post1052386
thanks
