IF-THEN-ELSE Action
  • #16
    Originally posted by jvm View Post
    Alternatively, if you go ahead with the If ... Then ... Else as you've proposed -- i.e., where the Actions are (generally) Easy Trigger actions -- I'd suggest also including the ability to run other Events as another option for the reasons I mention.
    Yes that's a good idea, so I will probably add a "Run Event" action as well as a "Control Device" action because this is probably the most used one, all other could be achieved using a "run event" action
    • #17
      Thanks for all the time you pour into this great PI.
      Option to respect or ignore event conditions would be a great detail to include, if possible.
      -Wade
      • #18
        I would make this first available to easytrigger's conditions and actions, not triggers. The IF in a IF-THEN-ELSE action would always be a condition not a trigger.
        But yes I think I would need to add some native basic condition like "A device's value is...", but I don't plan to re-code all of them.
        Yes conditions, sorry, triggers make no sense lol
        • #19
          Spud lets go to risk and ask him to open source the event engine, if they are willing we can do some pretty useful stuff here. Events is not their core IP, if anything HomeSeer is a driver (Zwave) company so they may be willing. And if not open source, perhaps close sourced to a few of us.
          • #20
            Another clarification -- I'm assuming the "Run Event" would behave like HS's current Run Event Action in that it would have an option "Only If Other Event Conditions Are True". This would allow you to use Event called by the Then or Else clause to created nested If... Then .. Else clauses; that is, the "Then" or "Else" section would each be able to run another Event with its own If...Then...Else and they, in turn, could call other events with If...Then...Else. Etc.
            • #21
              Having this would be super helpful, I can then finally convert my advanced scripts to be a bit more UI friendly for editing.
              • #22
                Any update on this? If Then Else is pretty basic and I am still surprised that it is not part of the basic event options. Once you have if then else, a case statement is easy simply a bunch of if then else else else.
                • #23
                  I would love to see this! I just moved from HS2 to HS3 and trying to use the group conditions is the dumbest thing I have ever seen. I hope Homeseer fixes this major bug in their system.
                  • #24
                    I strongly agree. Although I have always been a strong advocate of Easy Trigger -- I sing its praises regularly -- I believe that, ultimately, the best course is to rework the event engine. Considering that even relatively simple event bugs such as event triggers around midnight have been languishing for lengthy periods, and noting that HS appears much more interested in mobile applications than core event processing development, I'd guess that HS might decide that (semi?) open source of the event engine could turn out win-win for everyone involved.
                    If this proposal ever gains any traction, I would hope to be a substantial contributor. Until then, any plug-in support of If-Then-Else would be helpful.
                    • #25
                      I would love to see the event engine written to understand IF-THEN-ELSE. Having to create duplicate/triplicate events to get similar behavior has been frustrating as a HomeSeer user.
                      • #26
                        HS4's "Conditional Action" feature seems to address "If-then-else" type actions, though it won't be available for a while (HS says 2020), so I'm assuming at least a year.
                        https://homeseer.com/hs4-smart-home-...tion-software/
