Bug with latest version
    spud I have a bug with the latest version that makes no sense to me, when specifying the any time condition int he Group conditions it fails to set the value selected, so for example in the screenshot below, i cannot actually select the time range as it flips back to Select a Schedule
    other conditions like time after sunset etc, also show the same issue. but only when attempting to use as a group condition, when using in a normal event rather than an event group, it works fine.
    I need this to shorten my rule base.
    Third party Conditions will not work as a group Condition. This is not an Easy Trigger problem, it is a HomeSeer limitation. This s not a new limitation, it has always been the case.
    HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
      Really. I wasnt aware. I've worked around it now
        Good news, Rich has fixed this bug in HS3 version 3.0.0.523
          Very cool. I will give it a try.
