Event doesn't work when using trigger
    I Have an event that works perfectly if the easytrigger timeframe Is not there... but the minute I put it in as "AND IF",... it no longer seems to work. Best way to debug? Click image for larger version
Name:	Annotation 2019-05-26 102108.jpg
ID:	1307633Click image for larger version
Name:	Annotation 2019-05-26 102150.jpg
    Have you tried to create a new event in case the one you have is somehow corrupted?
      Nope...will try that....thanks
        This didn't work 😣.
        spud, any thoughts?
        Sent from my SM-T813 using Tapatalk
          This didn't work 😣.
          spud, any thoughts?
          Do you have any error in the logs when you start EasyTrigger, when you try to edit and close the schedule, or when the event is supposed to fire?
          Is your system time correct?
          To troubleshoot, try to create a much simpler event with a trigger on a virtual device, the same schedule condition and a simple Speak action.
            System time correct
            Turned debug on for EasyTrigger
            Stopped/Started the PI and saw the following:
            Jun-03 4:38:40 PM EasyTrigger DEBUG Device 1249 changed
            Jun-03 4:38:40 PM EasyTrigger DEBUG Device 1248 changed
            Jun-03 4:38:32 PM EasyTrigger INFO Found 0 device group value triggers
            Jun-03 4:38:32 PM EasyTrigger INFO Refreshing list of device group value triggers to monitor
            Jun-03 4:38:32 PM EasyTrigger INFO Found 0 random triggers
            Jun-03 4:38:32 PM EasyTrigger INFO Refreshing list of random triggers to monitor
            Jun-03 4:38:32 PM EasyTrigger INFO Found 0 schedule triggers
            Jun-03 4:38:32 PM EasyTrigger INFO Refreshing list of schedule triggers to monitor
            Jun-03 4:38:32 PM EasyTrigger INFO Found 0 device's value conditions that need monitoring
            Jun-03 4:38:32 PM EasyTrigger INFO Found 4 device's value triggers
            Jun-03 4:38:32 PM EasyTrigger INFO Refreshing list of device's value triggers to monitor
            Jun-03 4:38:32 PM EasyTrigger INFO Found 0 device's string triggers
            Jun-03 4:38:32 PM EasyTrigger INFO Refreshing list of device's string triggers to monitor
            Jun-03 4:38:31 PM Plug-In Finished initializing plug-in EasyTrigger
            Jun-03 4:38:31 PM Starting Plug-In EasyTrigger loaded in 532 milliseconds
            Jun-03 4:38:31 PM Starting Plug-In Plugin EasyTrigger started successfully in 84 milliseconds
            Jun-03 4:38:31 PM EasyTrigger INFO EasyTrigger version 3.0.0.54
            Jun-03 4:38:31 PM Starting Plug-In Initializing plugin EasyTrigger ...
            Jun-03 4:38:31 PM Info Plugin EasyTrigger has connected. IP:127.0.0.1:51127
            Created a new Schedule (Monday between 8am and 10pm) called FrontDoor
            Saw this in log:
            Jun-03 4:40:59 PM EasyTrigger DEBUG Device 401 value changed from 72 to 71.8
            Created a simple on/off virtual device with this event
            IF Test Unknown EasyTrigger Test Device changes and becomes On
            AND IF The time is in FrontDoor time range
            Then
            Set Device Light Office Overhead to On
            and turned on the VD
            saw this in log... so it did work
            Jun-03 4:52:07 PM EasyTrigger DEBUG Device 124 value changed from 0 to 99
            Jun-03 4:52:07 PM Z-Wave Device: Light Office Overhead Set to 99
            Jun-03 4:52:07 PM Device Control Device: Light Office Overhead to On (99)
            Jun-03 4:52:07 PM Event Event Trigger "Test events EasyTrigger Test"
            Jun-03 4:52:07 PM EasyTrigger DEBUG Device 1329 value changed from 0 to 100
            Jun-03 4:52:07 PM Device Control Device: Test Unknown EasyTrigger Test Device to On (100) by/from: CAPI Control Handler
            so at a loss why the other one won't work.
              EDIT... not sure why, but this is in the motion event part.. it's not working any longer. will troubleshoot elsewhere
                I'm back.. I still can't get this to work. I actually separated into two events, one that is triggered by the VD motion device (that is triggered by Blue Iris). This even manually kicks off the second event (set all tablets to view the front door camera), and then sets the VD motion device back to 'no motion'. This is set to not run again for 10 minutes.
                On the second event, I use easytrigger to only run this certain times of the day. I ran this as a test this morning with the easy trigger set to debug... and a time outside the range set for friday. HS3 time is correct.... and the even still ran.
                All screen shots are below...No idea why this is not working.
ID:	1310466Click image for larger version
ID:	1310467Click image for larger version
ID:	1310468Click image for larger version
ID:	1310469Click image for larger version
                  In your "Run event" action you did not check the "Run only if other event conditions are true" checkbox so the Easytrigger schedule condition is ignored.
                    My hero...thanks!
                      I feel like an idiot.. i'm trying to setup a similar event in a new house, and for the life of me cannot find the checkbox now. what am I missing?
                      Click image for larger version  Name:	Annotation 2019-09-26 073512.jpg Views:	0 Size:	121.4 KB ID:	1329017
                      edit nevermind ...i finally found it.
