I am using Homeseer v3.0.0.534 and EZ Trigger v3.0.0.65, EZ Trigger is enabled and has a "OK" status. When I create an event, only the standard stuff shows in the first "if" entry box. I have turned on debugging and EZ Trigger is running and showing all the devices that are changing. But it is not usable since I can't use it in a trigger.
EZ trigger not showing up in event creation
Well, my face it a bit red. I was looking at existing triggers and wanted to change them to trigger off of a "string" change. Apparently, once you create an event with one of the default triggers, you cannot later change it to spuds triggers later. I went back and created a new event and spud's triggers were all there. Thanks for all the help.
Originally posted by jimbell View PostApparently, once you create an event with one of the default triggers, you cannot later change it to spuds triggers later..
--Barry
Originally posted by jimbell View PostMy results are different than yours. I can create a new event and see all the easy trigger conditions. If I try to change the trigger of an existing event, they do not show up. Attatched are 2 screen shots. A new event and an existing event.
I have seen this bug on rare occasion after deleting a trigger. You can delete conditions but deleting triggers is likely to cause problems, so avoid that.
Anyway this is a bug in HS3 that affects all triggers, not just EasyTrigger.
