Startup logs
  • Startup logs
    just saw that i am using v 68. Do not know if this happened before.
    Sep-13 20:17:38 EasyTrigger INFO Found 5 device group value triggers
    Sep-13 20:17:38 EasyTrigger INFO Found 4 device group value conditions that need monitoring
    Sep-13 20:17:38 EasyTrigger INFO Refreshing list of device group value triggers to monitor
    Sep-13 20:17:38 EasyTrigger INFO Found 0 random triggers
    Sep-13 20:17:38 EasyTrigger INFO Refreshing list of random triggers to monitor
    Sep-13 20:17:38 EasyTrigger INFO Found 8 schedule triggers
    Sep-13 20:17:38 EasyTrigger INFO Refreshing list of schedule triggers to monitor
    Sep-13 20:17:38 EasyTrigger INFO Found 10 device's value conditions that need monitoring
    Sep-13 20:17:38 EasyTrigger INFO Found 10 device's value triggers
    Sep-13 20:17:38 EasyTrigger INFO Refreshing list of device's value triggers to monitor
    Sep-13 20:17:38 EasyTrigger INFO Found 77 device's string triggers
    Sep-13 20:17:38 EasyTrigger INFO Refreshing list of device's string triggers to monitor
    Sep-13 20:17:38 Error HSLogQueue count exceeded threshold! Clearing queue to prevent memory issues.
    Sep-13 20:17:37 EasyTrigger INFO Refreshing list of random triggers to monitor
    Sep-13 20:17:37 EasyTrigger INFO Found 8 schedule triggers
    Sep-13 20:17:37 EasyTrigger INFO Refreshing list of device's string triggers to monitor
    Sep-13 20:17:37 EasyTrigger INFO Refreshing list of device's value triggers to monitor
    Sep-13 20:17:37 EasyTrigger INFO Refreshing list of schedule triggers to monitor
    Sep-13 20:17:37 EasyTrigger INFO Found 77 device's string triggers
    Sep-13 20:17:37 EasyTrigger INFO Found 5 device group value triggers
    Sep-13 20:17:37 EasyTrigger INFO Found 10 device's value conditions that need monitoring
    Sep-13 20:17:37 EasyTrigger INFO Found 4 device group value conditions that need monitoring
    Sep-13 20:17:37 EasyTrigger INFO Found 10 device's value triggers
    Sep-13 20:17:37 EasyTrigger INFO Refreshing list of device group value triggers to monitor
    Sep-13 20:17:37 EasyTrigger INFO Found 0 random triggers
    Sep-13 20:17:36 EasyTrigger INFO Refreshing list of device's value triggers to monitor
    Sep-13 20:17:36 EasyTrigger INFO Found 77 device's string triggers
    Sep-13 20:17:36 EasyTrigger INFO Found 10 device's value triggers
    Sep-13 20:17:36 EasyTrigger INFO Refreshing list of device group value triggers to monitor
    Sep-13 20:17:36 EasyTrigger INFO Found 0 random triggers
    was not able to sent all the logs here. but I have 3 pages of this on hs3 log pages.
      issue is still there after a restart. Just sent you more logs via pm spud
        error is only present when hs3 starts.
        if I deactivate and activated the plugin back , it is ok :
        Sep-13 20:55:54 Event Event Trigger "google calendar poll with event"
        Sep-13 20:55:40 EasyTrigger INFO Found 4 device group value conditions that need monitoring
        Sep-13 20:55:40 EasyTrigger INFO Found 5 device group value triggers
        Sep-13 20:55:40 EasyTrigger INFO Refreshing list of device group value triggers to monitor
        Sep-13 20:55:40 EasyTrigger INFO Found 0 random triggers
        Sep-13 20:55:40 EasyTrigger INFO Refreshing list of random triggers to monitor
        Sep-13 20:55:40 EasyTrigger INFO Found 8 schedule triggers
        Sep-13 20:55:40 EasyTrigger INFO Refreshing list of schedule triggers to monitor
        Sep-13 20:55:40 EasyTrigger INFO Found 10 device's value conditions that need monitoring
        Sep-13 20:55:40 EasyTrigger INFO Found 10 device's value triggers
        Sep-13 20:55:40 EasyTrigger INFO Refreshing list of device's value triggers to monitor
        Sep-13 20:55:40 EasyTrigger INFO Found 77 device's string triggers
        Sep-13 20:55:40 EasyTrigger INFO Refreshing list of device's string triggers to monitor
        Sep-13 20:55:38 Plug-In Finished initializing plug-in EasyTrigger
        Sep-13 20:55:38 Starting Plug-In EasyTrigger loaded in 300 milliseconds
        Sep-13 20:55:38 Starting Plug-In Plugin EasyTrigger started successfully in 34 milliseconds
        Sep-13 20:55:38 EasyTrigger INFO EasyTrigger version 3.0.0.68
        Sep-13 20:55:38 Starting Plug-In Initializing plugin EasyTrigger ...
        Sep-13 20:55:37 Info Plugin EasyTrigger has connected. IP:127.0.0.1:44422
          issue is NOT present with v.67.
            Please test .69, it should be fixed. Thanks
              Hispud
              the version stays to .68 when i update
                Originally posted by MattL0 View Post
                Hispud
                It does update, but I think spud probably forgot to change the version tracking number.
                --Barry
                  please retry to install now
                    The issue is almost gone here is the logs ( it repeat two times). With .68 , the cpu time was going to 20 sec at startup. now it is normal at 3 sec with v.69
                    Sep-14 15:21:14 EasyTrigger INFO Found 4 device group value conditions that need monitoring
                    Sep-14 15:21:14 EasyTrigger INFO Found 5 device group value triggers
                    Sep-14 15:21:14 EasyTrigger INFO Refreshing list of device group value triggers to monitor
                    Sep-14 15:21:14 EasyTrigger INFO Found 0 random triggers
                    Sep-14 15:21:14 EasyTrigger INFO Refreshing list of random triggers to monitor
                    Sep-14 15:21:14 EasyTrigger INFO Found 8 schedule triggers
                    Sep-14 15:21:14 EasyTrigger INFO Refreshing list of schedule triggers to monitor
                    Sep-14 15:21:14 EasyTrigger INFO Found 10 device's value conditions that need monitoring
                    Sep-14 15:21:14 EasyTrigger INFO Found 10 device's value triggers
                    Sep-14 15:21:14 EasyTrigger INFO Refreshing list of device's value triggers to monitor
                    Sep-14 15:21:14 EasyTrigger INFO Found 77 device's string triggers
                    Sep-14 15:21:14 EasyTrigger INFO Refreshing list of device's string triggers to monitor
                    Sep-14 15:20:19 EasyTrigger INFO Found 4 device group value conditions that need monitoring
                    Sep-14 15:20:19 EasyTrigger INFO Found 5 device group value triggers
                    Sep-14 15:20:19 EasyTrigger INFO Refreshing list of device group value triggers to monitor
                    Sep-14 15:20:19 EasyTrigger INFO Found 0 random triggers
                    Sep-14 15:20:19 EasyTrigger INFO Refreshing list of random triggers to monitor
                    Sep-14 15:20:19 EasyTrigger INFO Found 8 schedule triggers
                    Sep-14 15:20:19 EasyTrigger INFO Refreshing list of schedule triggers to monitor
                    Sep-14 15:20:19 EasyTrigger INFO Found 10 device's value conditions that need monitoring
                    Sep-14 15:20:19 EasyTrigger INFO Found 10 device's value triggers
                    Sep-14 15:20:19 EasyTrigger INFO Refreshing list of device's value triggers to monitor
                    Sep-14 15:20:19 EasyTrigger INFO Found 77 device's string triggers
                    Sep-14 15:20:19 EasyTrigger INFO Refreshing list of device's string triggers to monitor
                    Sep-14 15:20:01 EasyTrigger INFO EasyTrigger version 3.0.0.69
