Dealing with Value Ranges & Door Locks
    PROBLEM: use Value Range for a SINGLE device within an ET Group to Trigger an event
    GOAL: Trigger when specific door lock codes are entered. ET doesnt seen to properly use, or maybe see, the door lock codes
    Need Help with...
    What ET Trigger to use (Expression, Range, etc), and how to use it.
    ... ANY ET Group value change AND the specific changed Device Value (not any other device) is now within a range 6002-6009 but not 6005.
    ET Group Devices are: Front Door (Access Control Notification) & Garage Door (Access Control Notification)
    spud help please!
    Ltek I have a battery check function that I think is conceptually similar to what you want to do. I have a Easy Trigger group of battery devices ("Batteries") where, if one reports status, a check is done and a message sent if the level is too low. The message uses various global variables to identify the name, location, and status value of the Battery. I think this might give you enough guidance to solve your problem. I think you'd only need to change the "Batteries" group to a "Lock" group. This assumes you can use global variables in Pushover (I don't use Pushover myself, so my example is for an email (text) alert).
    See:
      jvm Thx, but I'm already using groups and its not working due to need a value range. sorry if that wasnt clear, I'll update the first post.
      spud Can you help me figure out how to accomplish this? thx
        Originally posted by Ltek View Post
        Goal... Trigger when specific door lock codes are entered.
        Using an ET Group with both Devices already in it but cant figure out what Condition to use (Expression, Range, etc)?
        I need the event to see if ANY group value changed AND if that changed value (not any of the others) is now within a range 6002-6009 but not 6005.
        Devices:
        Front Door - Access Control Notification
        Garage Door - Access Control Notification
        Output: Pushover message telling me what Door was used, and what code was used
        thx for the help!
        I think this would work, but i haven't tested it to be sure...
        --Barry
          Ltek , logman
          I think logman's solution should work - you should also be able to write the expression as one line. I.e.,
          ($$GLOBALVAL:etDeviceValue: > 6001) && ($$GLOBALVAL:etDeviceValue: < 6001) && ($$GLOBALVAL:etDeviceValue: != 6010)
            Originally posted by jvm View Post
            Ltek , logman
            Yes, and that is also simpler. Also the first "AND IF" is not really necessary, because the primary trigger is already checking for that value. I just added it in there to make it more clear how the range was defined. So actually your condition expression could be:
            ($$GLOBALVAR:etDeviceValue: < 6010) && ($$GLOBALVAR:etDeviceValue: <> 6005)
            --Barry
              Thank you guys!
              I think the expression I need is...
              ($$GLOBALVAL:etDeviceValue: > 6001) && ($$GLOBALVAL:etDeviceValue: < 6010) && ($$GLOBALVAL:etDeviceValue: != 6005)
              ... thus trigger when values are between (and equal to) 6002 & 6009, but not 6005.
              I'll try that!
                Guys, that didnt work... it didnt trigger at all
                Here's what the values of show with a more normal drop-down list... those 'Codes' translate into numbers like 6002, 6003 on the back-end. Maybe there is an issue where ET is not seeing the actual code #s?
                spud
                  I'm sure range is nice, especially if you ever add new codes, but if you just create 7x "OR IF" entries for the codes that aren't 6005, wouldn't that be easy if it works?
                  Or is it not triggering on a single code either?
                    Ltek - A few thoughts . . .
                    1. Update the Easy Trigger plugin if you are not using version (3.0.0.70). The most recent version fixed some problems in the settings of global variables.
                    2. Make a change to your door lock which you believe "should" trigger your event. Then go to the [Tools] -> [Global Variables, Timers, & Counters] page on your HomeSeer site - is the "etDevice Value" value what you expected ?
                    3. Maybe the problem is in Pushover? Try a different "Then" action - e.g.,turn on a light do something else instead of trying to send the Pushover message. Anything happen?
                      It could be too that there is another event firing nearly at the same time that is messing with your global variables. I've ran into that issue a few times and it's always a hair puller until I figure it out. Don't really know of a work around if that's the problem, other than delaying the second event (which is not always a viable solution).
                      --Barry
                        Well after posting the above I see you started another thread and had already discovered that was the issue. Hopefully Spud will provide a fix as you suggested by using a different set of variables per event.
                        --Barry
                          Guys, I guess I wasnt clear so I updated the first post as below.... please forget about Pushover, that was never the problem
                          Need Help with...
                          spud help please!
                            Need Help with...
                            spud help please!
                            use this:
                            if that doesn't work set the log level to debug, and you will see what changes the ET plugin is seeing, what the expression is evaluated to, and what event it is triggering
