easytrigger and if , or if
asko.lahd@gmail.com
I'm not na expert, and this is not related to your issue but I think you should change yours triggers. In my opinion the trigger should be "If the temperature has a value that is greater than..." instead of the timer range. I think the way you currently have can cause some overload on your system ... so I advise you to change to the following:
If Your Temperature Device has a value that is greater than 19.7
and if The Time enters Your Timer time range
Then.....
Do the same to the other event. I repeat, I am not an expert but I think it gets better. It may be that someone with more experience can confirm what I say.
ok thanks for the test, this is a vacation home heat control
I would think that the RFXcom statements should come first before the time ranges (schedules) so that your triggers checked again based on the schedules before they fire.
Where and how you add the schedules seem to be where the problem is.
Try and remove the timers (schedules) and see if your events fire. And try to post your queries here : https://forums.homeseer.com/forum/ho...3-event-clinic or here https://forums.homeseer.com/forum/ho...iscussion-area for the best help.
Eman.
Originally posted by asko.lahd@gmail.com View PostHi easytrigger triggers do not work whether it is a defect in homeseer or easytrigger. The log shows temperature changes correctly but no triggers. I have tested and phrases, or if the trigger works but does not, and if with. sorry I use a translator
I may be wrong but wait for more expert help.
Eman.
Hi easytrigger triggers do not work whether it is a defect in homeseer or easytrigger. The log shows temperature changes correctly but no triggers. I have tested and phrases, or if the trigger works but does not, and if with. sorry I use a translatorTags: None
