Avoid dimming value <0 and >99%
    Hi,
    Im using 'Set Device to Another Device to dim or bright a lamp on (up./down) Keypress. In this example dimming 17%. How can i avoid that the value becomes negative ( <0 or when using +17 the value becomes >99%) So the values must be locked to min 0% and max 99%. I think with some regular expression i can do?
    Walter
    Try this :
    Then EasyTrigger "Set device to expression"
    "Begane grond Woonkamer..." Max($DEVICEVALUE-17,0)
    And
    "Begane grond Woonkamer..." Min($DEVICEVALUE+17,99)
      Hi Michel,
      This was exactly what i needed and its working Thanks for your help! I just starting with EasyTrigger and has some learningcurve
      Walter
