Jan-18 14:49:13 | EasyTrigger | ERROR System.ArgumentException: '0' is not a valid value for 'Interval'. 'Interval' must be greater than 0. at System.Timers.Timer.set_Interval (System.Double value) [0x0002e] in :0 at HSPI_EasyTrigger.TriggerTimers.DeviceValueHasBeenTriggerTime r.Update (System.Boolean value, System.TimeSpan forExactly) [0x00030] in :0 at (wrapper remoting-invoke-with-check) HSPI_EasyTrigger.TriggerTimers.DeviceValueHasBeenTriggerTime r.Update(bool,System.TimeSpan) at HSPI_EasyTrigger.EasyTriggerApp.CheckDeviceValueHasBeenTrigg er (System.Double curDeviceValue, HSPI_EasyTrigger.DeviceValueTrigger valueTrigger) [0x00105] in :0 at HSPI_EasyTrigger.EasyTriggerApp.CreateDeviceValueTriggerForG roup (HomeSeerAPI.IPlugInAPI+strTrigActInfo trigInfo, System.Int32 dvRef, System.Boolean isCondition) [0x00041] in :0 at HSPI_EasyTrigger.EasyTriggerApp.RefreshDeviceGroupValueToMon itor () [0x00152] in :0 |
[SCHEDULES]
Schoolschedule=[Mon 05:15;Mon 08:00],[Tue 05:15;Tue 08:00],[Wed 05:15;Wed 08:00],[Thu 05:15;Thu 08:00],[Fri 05:15;Fri 08:00],[Sat 07:00;Sat 09:30],[Sun 07:00;Sun 09:30],[Mon 15:00;Mon 22:00],[Tue 15:00;Tue 22:00],[Wed 15:00;Wed 22:00],[Thu 15:00;Thu 22:00],[Fri 15:00;Fri 23:00],[Sat 20:00;Sat 23:00],[Sun 20:00;Sun 23:00]
Heat_on_BR=[Mon 05:00;Mon 08:00],[Tue 05:00;Tue 08:00],[Wed 05:00;Wed 08:00],[Thu 05:00;Thu 08:00],[Fri 05:00;Fri 08:00],[Sat 06:00;Sat 09:00],[Sun 06:00;Sun 09:00],[Mon 20:00;Mon 23:00],[Tue 20:00;Tue 23:00],[Wed 20:00;Wed 23:00],[Thu 20:00;Thu 23:00],[Fri 20:00;Fri 23:00],[Sat 20:00;Sat 23:00],[Sun 20:00;Sun 23:00]
Heat_on_commonareas=[Mon 06:00;Mon 08:00],[Tue 06:00;Tue 08:00],[Wed 06:00;Wed 08:00],[Thu 06:00;Thu 08:00],[Fri 06:00;Fri 08:00],[Sat 07:00;Sat 10:00],[Sun 07:00;Sun 10:00],[Mon 18:00;Mon 22:00],[Tue 18:00;Tue 22:00],[Wed 18:00;Wed 22:00],[Thu 18:00;Thu 22:00],[Fri 18:00;Fri 22:00],[Sat 18:00;Sat 22:00],[Sun 18:00;Sun 22:00]
[GENERAL]
log_level=Info
[DAY_SCHEDULES]
CoolMBR=[00:00;08:00],[20:00;23:59]
CoolGR=[06:00;08:30],[14:00;22:00]
TVtime=[20:00;23:00]
[DYNAMIC_DEVICE_GROUPS]
1###name=Batteries
1###rule_0_0=Type,Contains,False,Battery
2###name=Water
2###rule_0_0=Type,Contains,False,Water
If I have a misconfigured event, how would I find it?
Thank you,
Devan
