I have a few events that use Groups as a trigger as in:
If
"Any device in Group Garage has changed and becomes 0"
Then
This triggers OK, but if I go and edit the trigger to:
If
"Any device in Group Garage has just changed"
Then
The event will not trigger. Instead of just being able to edit the trigger I have to delete the event and create a new event with the new trigger and it works just fine then.
This may have failed in HS3 also but I didn't need to alter the trigger in HS3. Some behavior in HS4 forced me to change the trigger.
If
Then
If
Then
