HS4 Linux Build 37 - Changing Event trigger when using Groups
  • andyf
    Originally posted by Ltek View Post
    Just to let you know, I'm running HS3 w/ exact same event (two MyQ garage doors in the Group) ... it triggers fine for me everytime.
    If you create the event with that trigger it works fine. If you create the event with "has changed and becomes <a value>" and then change your mind and edit it to "has changed" only is when it fails to trigger.
  • Ltek
    Originally posted by andyf View Post
    If
    "Any device in Group Garage has just changed"
    Then
  • andyf
    started a topic HS4 Linux Build 37 - Changing Event trigger when using Groups
    I have a few events that use Groups as a trigger as in:
    If
    "Any device in Group Garage has changed and becomes 0"
    Then
    This triggers OK, but if I go and edit the trigger to:
    If
    Then
    The event will not trigger. Instead of just being able to edit the trigger I have to delete the event and create a new event with the new trigger and it works just fine then.
    This may have failed in HS3 also but I didn't need to alter the trigger in HS3. Some behavior in HS4 forced me to change the trigger.
