Pass Device Value to a Virtual Device
    I want to pass my current HS3 device pool temperature to a virtual device once per hour, unless there is no change, or no data (when the pump is off). That way the last temperature will show on my HSTouch app for pool control/monitoring, instead of showing null value when the pump is not running. I may be doing something wrong, but I don't see how to do this easily (for me). I can get the schedule working, but am not updating the virtual device (perhaps I created the wrong type device?). Any guidance would be appreciated. This is what I created for my Event:
Name:	Temperature Event.png
    Looks like you have the two devices reversed.
    HS 4.2.8.0: 2134 Devices 1252 Events
    Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
      Is HS controlling the pool pump?
        Yes.
        HS4 Pro, Windows 10 pro
          Yes, HS is controlling the pump through the iAqualink plugin.
            sparkman you were correct, they indeed were reversed. I didn't understand the syntax correctly. Thanks for the help!
