Help with Regular Expression
    I'm trying to match these possible strings inside a device status within a longer string. I've been at this for a few hours and I'm calling uncle...
    Any help is much appreciated.
    Movies
    Sports
    TV Shows
    TV Recordings
    RJ_Make On YouTube
    Try this- This is searching for words on a word boundary.
    \b(Movies|Sports|TV|Shows|Recordings)\b
      Thank you! It now fires the event, so that's a much better result then I got..
      HOWEVER
      It fires on any word in the group and not on the exact statements below.
      Example: If the status is Temp Movies, it firing (I'm guessing because it has the work Movie in it), but I need to only fire on the full Strings
      Movies
      Sports
      TV Shows
      TV Recordings
      RJ_Make On YouTube
        Do you want to test a string that just contains movies, Sports, TV Shows, TV Recordings?
        Can you Share the Strings you are trying to parse?
          Try
          ^(Movies|Sports|TV|Shows|TV Recordings)$
          or
          ^Movies$|^Sports$|^TV Shows$|^TV Recordings$
            Yes, here is what a possible string would look like.. They could contain other/additional verbiage but this is the jist of it.
            Midway was recently added to Movies
            RJ_Make On YouTube
              Originally posted by zwolfpack View Post
              Try
              or
              Thanks for you help, neither seemed to work. Would not fire the event.
              RJ_Make On YouTube
                Given your example, try this instead
                or
                added to (Movies|Sports|TV|Shows|TV Recordings)$
                The '$' at the end indicates that the substring has to be at the end of the given string. My previous suggestion with the '^' at the start indicates that the string needs to start with the substring. (With both the '^' and the '$', the string has to match the substring exactly, which turns out not to be what you wanted).
                  Let's get back to basics
                  Here is a website that will allow you to test your Regex.
                  https://regex101.com/
                  Here is a site with cheatsheet of Regex syntax.
                  https://www.rexegg.com/regex-quickstart.html#chars
                  Here is the text String I utilized to test the regex: "Midway was recently added to TV sHows temPa MovIes "
                  The Regex that will identify the wanted terms regardless of case is: \b((?i)(?<!Temp\s)Movies|Sports|TV\sShows|TV\sRecordings)\b
                  In the test, It identified both "TV sHows" and "Movies". This is because Temp did not precede Movies but temPa did. If you delete the a it will find TV sHows only.
                  I think this will work in the long run regardless of text before or after.
                    Thank you so much guys. The solution provided by zwolfpack and AllHailJ worked.
                    I generally stay far far away from "Regular" (nothing regular about them) Expression but really needed to use it here.
                    Again, Thank You!
                    RJ_Make On YouTube
                      Regularly confusing!! Glad you got it working.
