What I want to do is put all my HS-WD200+ scene controllers in an Easytrigger group so that when I tap any wall HS switch "x" number of times it run the same event without creating more than 20 individual triggers 1-by-1 for each and every switch. Even with several suggestions I just can't seem to get this to work. "If" this is possible can someone please post the exact event trigger syntax.
I could go into all the things I've tried, but to keep this simple it would be awesome if somebody just posted the answer.
Many thanks in advance.
