Please someone tell me what am I doing wrong here.. see attached. No matter what condition I put, it is always evaluating to "true":
Using Replacement Variables in EasyTrigger
Firstly you're doing too much work in that AND IF condition, you can simply do:
Condition: A Device's Value Is
Trigger Type: This Device Had its Value Set and is Not Equal to (being an AND it won't do the "set" bit only the "not equal to")
Trigger Value: 0
However being a manually run event the conditions aren't actually used - it runs regardless.
If you are firing that event VIA another event there is a new option in HS4 to enable processing the conditions of a manual event if that's what you are trying to do?
Or if you are simply manually testing then you'll need to set a recurring trigger to have the condition evaluated.
Hope one of these help?
Originally posted by Tillsy View PostFirstly you're doing too much work in that AND IF condition, you can simply do:
Trigger Value: 0
I started off with a simple condition check, but I was launching the event manually. I was in a fog and didn't realize that the manual launch not only skips the trigger, but it also skips checking the conditions. Tested it with a recurring trigger event and everything is good to go... Thanks again!
Sam
- 1 like
