Change brightness of a group of dimmers base on virtual device
    Use case:
    change brightness of a group of dimmers based on a virtual device (ref 3858 here) that ranges from -100 to 100
    (all dimmers have a 0-100 range)
    The individual changes for each dimmer must be relative to the existing values and can't go below 0 or above 100.
    The intent is to change multiple dimmers brightness up/down relative to existing values.
    Pretty sure I'm on the right track but I need to assess the 0-100 resulting value and only apply if within range.
    where below it checks the current value and applies the change if within range.
    if ($DEVICEVALUE <= 100 and $DEVICEVALUE >= 0, $DEVICEVALUE + $$DVR:3858:, $DEVICEVALUE )
    Example of expected behavior for 3 dimmers
    Dimmer 1= 25
    Dimmer 2 = 90
    Dimmer 3= 100
    If virtual device is set to 25:
    Dimmer 1= 50
    Dimmer 2 = 100
    Dimmer 3= 100
    then If virtual device is set to -25:
    Dimmer 1= 25
    Dimmer 2 = 75
    Dimmer 3= 75
    then If virtual device is set to -80:
    Dimmer 1= 0
    Dimmer 2 = 0
    Dimmer 3= 0
    If you want to check the result, then the operation needs to be in the first argument of the IF. How about this?
    if ($DEVICEVALUE + $$DVR:3858: >= 100, 100, if ($DEVICEVALUE + $$DVR:3858: <=0, 0, $DEVICEVALUE + $$DVR:3858: ))
    Double-check my syntax.
    -Wade
      Works perfectly
      Didn't think you could use another IF-ELSE within the operation
      Thanks Wade
      Yann
        Glad I could help.
        -Wade
