Copy Device A (String) to Device B (String)
    I have created a "Device A" and used "Easy Trigger Set Devices String" to set the devices string. (i.e. Device A = "OK Google").
    Now I want to copy "Device A's string" to "Device B". I tried "EasyTrigger: Set Device to Another Device" but it does not work. (probably doesn't work with strings)
    Do I need to create a script to do that or is there an easier way without scripting?
    Doug
    I think you will need to write a script activated by an event. You will need the refid for device A & B
    sub main()
    Dim s As String
    s=hs.DeviceString(RefID-for-Device-A)
    hs.SetDeviceString(RefID-For-Device-B, s, True)
    end sub
    You may also have to set the timestamp on the devices so the system recognizes they have changed.
      Thanks for the quick response.
      I thought that would probably be the case.
      All the best,
      Doug
