Purchased Easytrigger mainly for this... what's the best way to do a 'wakeup" light in easy trigger?
How do you do gradual bright?
Use a recurring trigger of once a second or at whatever rate you want the light to increase.
Create a virtual device to control the light
Use a condition to determine the maximum level you want the light to reach
Use the Easy Trigger “Set Device to another Device” as the Action. Set the light to itself + 1
IF this event will trigger once every second
AND IF light virtual is On
AND IF the light is less than 70%
THEN set light to light +1
When the virtual device is on, the light will increase by 1% each second until it reaches 70%. You will need to turn the virtual device off when the light is Off.
IF light is set to Off
THEN turn light virtual Off
