At least keeps reverting to exactly
    Hi,
    I have a motion event that I would like to trigger but only trigger if a light has been on for at least 5minutes. However it works once and then when I check the logic homeseer has reverted the condition back to "Exactly". As the second condition has a different time to the first it will never trigger. Is this a bug in HS4 with easytrigger or have I done something wrong.
    Logic is
    If motion sensor is " No motion" for exactly 10mins
    And if
    The light has not been in the range of 0,0 for at least 5 minutes
    Then
    Turn the light off
    The second condition stops the light being turned off for at least 5mins if it has been manually turned on and motion has not been detected ( quite an odd shaped room ).
    I'm sure this should work but it always reverts to EXACTLY for both conditions after running once..
