sunset and sunrise variables in Easytrigger expressions
    I know sunset and sunrise variables are available somewhere in HomeSeer, but I'd like to use them in an expression. This is to set color temperature of lights to a different value every few minutes, based on how far away from sunset or sunrise. I don't see sunset/sunrise listed as a replacement variable. Is there a way to access that from within Easytrigger expressions?
    And if I can find them, can I add and subtract those variables (to get a number of seconds since sunrise or until sunset, for example)?
    There are standard triggers:
    If the time is this before / after sunrise / sunset
    Won't those do what you want?
      I don't think scripting variables are available to Easytrigger, but you could use these in an event with Easytrigger. https://help.homeseer.com/help/HS3/s...#.time_related
      HomeSeer Version: HS3 Pro Edition 4.2.6.0
      Operating System: Microsoft Windows 10 Pro - Desktop
      Enabled Plug-Ins
      AK Google Calendar 3.0.0.45,AK Smart Device 3.0.0.6,AK Weather 4.0.1.77,AmbientWeather 3.0.1.9,Big5 1.38.0.0,BLBackup 2.0.63.0,BLGData 3.0.55.0,BLLock 3.0.38.0,BLPlex 2.0.22.0,BLUPS 2.0.26.0,Device History 3.2.0.2,EasyTrigger 3.0.0.74,HSBuddy 3.25.614.1,mcsMQTT 5.21.4.1,MeiHarmonyHub 3.1.0.22,NetCAM 3.0.0.14,PHLocation 3.0.1.109,Restart 1.0.0.7,SDJ-Health 3.1.0.3,SDJ-VStat 3.1.0.7,TPLinkSmartHome 19.10.7.1,UltraCID3 3.0.6681.34300,UltraSighthoundVideo3 3.0.5960.36744,,Z-Wave 3.0.2.0
        Thanks for the suggestions!
        I already change the color temperature of the lights using sunset/sunrise standard triggers, but only with 4 events. It works fine but the change is a little obvious when it happens. I wanted to change them every 5 minutes, so that each individual change isn't noticeable, but if I used standard triggers, that would be over 100 events. I'd rather use some kind of expression.
        I haven't got into scripts yet but I should spend some time figuring it out, I think that's probably the best way to handle this since the scripting variables are exactly what I need for this.
          I think you are on the right track to consider a script. One possibility that comes to mind would be a recurring event which runs a script that changes the light settings incrementally. I am not familiar with the commands to adjust color temperature of your lights, but if they allow a change as a percentage of the existing settings, then that is one possible way to achieve what you want with a relatively simple script.
            Not sure if you could achieve what you want with that but note that you can build schedule time ranges relatively to sunrise and sunset, see bottom of this post:
            https://forums.homeseer.com/forum/ul...41#post1347341
              I did actually use those scheduled time ranges and ended up triggering events based on those, it's a little more convenient than doing the logic in the events themselves. But I'm still just triggering events with them, and each event sets the light to a specific color temperature. Is there a way to use scheduled time ranges as a variable in an expression?
