Toggle feature not working correctly with x10 module
    Hi there,
    I've got a few x10 lamp modules that I'd like to toggle on/off, but when I select ON or OFF in the toggle section, my selection keeps going to 2% or 3%. It does change to ON for a second before the screen refreshes and it changes to 2% (or OFF changes to 3%).
    I'm attaching a screen shot. Any help would be great!
    Thanks!
    X10 default On is a value of 2 and Off is a value of 3. How are these lights controlled?
      can you post a screenshot of the Status/Graphics tab for this device?
        Thanks guys. I can confirm that it appears to be working when I leave the values at 2 and 3%. Also from the status graphics section, it appears that there are redundant On/Off commands.
Name:	toggle problem2.png
          The problem is that there are several controls defined for values 2 and 3. They are single controls On/Off buttons but they are also part of the 1-99 dim range. This is wrong and that's why Easytrigger is confused.
            Makes sense now and my setup is working now. FWIW I did not create the table. It was what HS3 defaulted to when adding the module.
