Originally posted by spud
View Post
Error message in log
"Set Device Value" is probably better but it's not perfect either because all those "Set Device...." actions actually "control" the device if they find a CAPI control for this value, if no control is found then they just update the device value.
Originally posted by Wade View Postspud, related to this topic...I had similar confusion with this ET action as well as "Set device to device". It wasn't clear to me what properties would be copied from one device to the other. Over time I came to figure out it's only the value. Minor suggestion for for user convenience: Change action names to "Set Device Value to Expression", "Set Device Value to Another Device", "Set Device Value to Variable".
Thanks.
Thanks.
the "Set Device To Expression" action only works with numerical values, the expression needs to result in a number, that is used to control the device. You can't use that to set the device's string.
if you just want to set the device's string to the current date, I think you can use the "Set Device's string" action.
HS4 4.2.4.0
EasyTrigger 3.0.0.71
I'm getting this in the logs:
The event is trying to set the device to an expression, but using replacement variables:
RobTags: None
