Is there a way of writing an average device value to another device?
  • TC1
    You're trying to reinvent the wheel. Simply pull the Average value for the last hour from Device history and put that value in a virtual device that you can use in Events, HSTouch, etc.
    I don't use Device History (I use Jon00's Charting) but I'm sure there's a way to pull the Average value calculated in the chart you're showing.
  • Join
    Originally posted by 123qweasd View Post
    Create a virtual device for average power (kW)
    When your original device is "set" (every 10 sec)
    just have ET update your virtual device with ((new value+virtual device value) /2)
    You could create a third VD to calculate/write the hourly energy consumption (kWh) if needed.
    Check ET help for "set device to expression"
    Here is an example.
    This is a graph collected with the Device History plugin:
    It shows the current Last hour power consumption, and the result is 2,7kWh.
    I am looking to see if it's possible to do with EasyTrigger.
    Mabye with 60 virtual devices, adding together /60=average-ish?
  • 123qweasd
  • Is there a way of writing an average device value to another device?
    Hi!
    I got a device that read realtime power consumption in my home.
    I am looking for a way to calculate the last hour power (kW) consumption and write the result to a virtual device every 10seconds or so.
    Resulting in valus like: 2.5kWh, 1.03kWh, 0.85kWh etc.
    Is there a way to do this?
    Best regards
    Join
