Trigger-was and becomes
    I am trying to use the trigger, "this devices value was and becomes" and I am trying to do a single value, the was is "-1" and the becomes is "0" but it does not seem to actually trigger on the event. I did try it with a different value that was not a negative number on another device to see if it was the negative being the issue but that other event did not work either. The device in question is a status only device.
    If you post a screen shot of the event the nature of the problem may be easier to determine. I gather that you have not assigned status labels to the relevant device values.
      Here is the event . Click image for larger version
      Here is the device, I do have the status values there but they do not display in the drop down as value options for ET.
        I see no Status Text or Controls. Even for a Status Only device you have to have Status Text and just use the Status button to denote not to put up any controls on the interface. Rather sure that's your problem.
        Add a Status Text pair for -1 and 0 and EasyTrigger should work fine. ET uses Status Text to determine changes.
          I agree.
          You can add the status text labels in the space above where you added the graphics labels.
          ('NEW SINGLE VALUE' and 'NEW RANGE VALUE' buttons)
            Originally posted by Uncle Michael View Post
            I agree.
            In the Edit controls section?
              Yes
                I don't think that's the problem. EasyTrigger rely on values and not on status text to determine changes.
                Dweber85rc, try to set the log level to Debug in EasyTrigger config page, and check in the logs if the plugin is seeing the device value changing.
                  Yes I see the device value changing
                  DEBUG Device 1014 value changed from 0 to -1
                  12/5/2021 5:34:42 PM
                  HomeSeer
                  12/5/2021 5:33:06 PM
                  Legacy-Plugin
                  EasyTrigger
                  DEBUG Device 1014 value changed from -1 to 0
                    spud ?
                      I've just tested this with a virtual device and an event configured exactly like in your screenshots, and it works for me.
                      Are you sure the device you select in the trigger is id=1014? you may have several devices named the same, you can use the version beta 3.0.0.75, so that ET uses HS4 styles names for devices.
                      Also in your screenshot, your event shows that it is disabled......
                        Yes I am aware the event is disabled. It wasn't working and I didn't want it randomly working so I disabled it. The device in question, 1014, is the correct device Id. I am working on trying this with a different device just to verify that the logic is correct and working.
                          spud I tried this with some different devices and am getting the same result. The event never runs. I do not know what event 194 is. The triggering virtual device # is 1022, I have a separate event that is setting the status manually, either to 0 or 100.
                          12/19/2021 2:16:05 PM
                          Legacy-Plugin
                          EasyTrigger
                          DEBUG Firing event 194
                          Legacy-Plugin
                          EasyTrigger
                          DEBUG Device 1022 value changed from 0 to 100
                          Legacy-Plugin
                          EasyTrigger
                          DEBUG SetDeviceValue: Cannot find control value 100 for device 1022, will set device value instead of controlling it using CAPI
                          Legacy-Plugin
                          EasyTrigger
                          DEBUG Expression $100 evaluated to 100
                          HomeSeer
                          Event
                          Event Trigger "Vehicle Patriot Home Status - Home"
                          HomeSeer
                          Event
                          Event Vehicle Patriot Home Status - Home triggered by the events page 'Run' button
                          This is also on the Beta 3.0.0.75.
                            Not sure why but it started working correctly tonight. The only thing I did was my homeseer machine got rebooted last night.
