Schedule copying error 3.0.0.74
    Just seen the following error with EasyTrigger 3.0.0.74 on HS4 4.2.6.0 (Linux based) when trying to setup an event to switch schedules. Any ideas?
Name:	easy trigger error.jpg
    Thanks in advance.
    I can't reproduce this problem, can you reproduce it every time you try to create a "Set Schedule to another Schedule" action?
    Please post the content of your Config/EasyTrigger.ini file
      Yes, repeatable every time I try to create this action. The system was upgraded from v3 if that makes a difference, not a fresh install. Here is the contents of the file.
      [SCHEDULES]
      Heating=[Mon 07:30;Mon 10:00],[Tue 07:30;Tue 10:00],[Wed 07:30;Wed 10:00],[Thu 07:00;Thu 09:30],[Fri 07:00;Fri 09:30],[Sat 07:00;Sat 09:30],[Sun 07:30;Sun 11:00],[Mon 17:00;Mon 22:30],[Tue 17:00;Tue 22:30],[Wed 17:00;Wed 22:30],[Thu 17:30;Thu 22:30],[Fri 17:30;Fri 22:30],[Sat 17:00;Sat 22:30],[Sun 17:00;Sun 22:30]
      BackdoorLight=[Mon 17:30;Mon 18:30],[Tue 17:30;Tue 18:30],[Wed 17:00;Wed 20:00],[Thu 17:30;Thu 18:30],[Fri 17:30;Fri 18:30],[Sat 17:00;Sat 18:00]
      [DAY_SCHEDULES]
      SittingRoomHeat=[16:00;00:00]
      [DEVICE_GROUPS]
      Batteries=350,356,306,353,274,422,347,627,636,645,624,603,61 6
      GuestRoomTemps=630,939,948
      GuestRoomSetpoints=633,942,951
      KitchenTemps=789,874,883
      KitchenSetpoints=792,877,886
      Occupancy=665,815,666,814,663,816,667
      SittingRoomTemps=869,735
      SittingRoomSetpoints=867,738
      MasterBedroomTemps=930,920
      MasterBedroomSetpoints=933,923
      Zones=818,819,830,820,964
        I have just removed the unused Day schedule (SittingRoomHeat), and am now able to define the action. So clearly there is a problem when you have both Day and Week schedules defined.
          I can see the problem now, it will be fixed in the next version.
          Thanks for reporting.
            No problem. Will we be able to replace a week schedule with a day schedule? My use case is a normal week based heating schedule being replaced by a day schedule for specific dates that are flagged for an early start.
