Is "Device Has NOT Been In Range/Changed For At Least" Not HS4 Friendly?
    Spud,
    Tonight I was creating some simple events to control lighting when I discovered that the Easy Trigger conditions "This device's value has NOT been in range [X,Y] for at least" and "This device's value has NOT changed for at least" were not letting events run even though the conditions were true. I confirmed all conditions were true by eyeballing the condition devices. So I began backing conditions out of the events and confirmed it was the ET conditions that were stopping the events from running.
    Below is a picture of one of the events:
    I know the Trigger "For At Least" was deprecated from HS4, but I thought it was still ok to use as a condition. i'm pretty sure I have some HS3 legacy events with these ET conditions and those events are still working fine (AFAIK).
    Would you mind taking a look at this? Not sure at this point if it's a feature or a bug.
    --Barry
    Have you waited for at least 30 minutes after you created the event to test it?
    All the "for at least X minutes" condition in EasyTrigger are based on the plugin actually monitoring device values, so all those conditions are always false on the first X minutes after the plugin starts or after you modify any event.
    But those conditions are definitely still supported in HS4.
      Hmm, you know that could have been the problem. I never realized that. I just assumed the plugin did the math on the last status change time recorded by HS4. I didn't realize the plugin kept its own timesheet, so to speak. I'll test again and see if that was the problem.
      --Barry
        Is there a workaround for this?
          This is a native trigger, so it's not related to the EasyTrigger plugin.
          The workaround is to use a recurring trigger + a "has been for at least" condition
            Thanks for the info
