Set device group to one device?
    I know I can set one device to match another, but can I set it to a whole group? Ie. Dimmer in my office could dim up and down entire main floor.
    Here's one idea: If your dimmer has central scene capability, then use an event that triggers when the either the Up or Down paddle has a long release, which happens when you are holding the paddle to dim and then achieve your desired level. The action in the event will then set the EasyTrigger group to the device value of the dimmer's light. Below I used my living room dimmer to set the value for multiple kitchen lights.
      Thank you. This works great. I was playing in the section but didn't know what to use for an expression.
        Awesome, glad it worked out. It was just something I threw together quickly for your use case and wasn't 100% sure it was bullet-proof.
        For the expression possibilities, you need to click here:
