how to set up device variable
    I create an event to control a dimmer up . I had error when I run. Can your point out where the mistake I make? Thanks.
    This is the error I got.
    Legacy-Plugin EasyTrigger ERROR SetDeviceValueToVariable: Cannot parse variable to a numerical value
    This is the event I create.
    IF
    This event is MANUALLY triggered
    THEN
    Set Device Home Hallway HomeSeer HS-WD200 Dimmer Light to variable $$DVA(390): + 1
    Ken.238
    Edit:
    $$DVR:390: + 1
    Assuming 390 is a devref. DVA is Dev Address
    http://help.homeseer.com/help/HS3/st...ment_variables
      Thanks for your help. It work perfect.
